soundcrossing's avatar
Nov 03, 2016
EX3800 Unable to Connect a Device to 5G
  • Hardware Version: EX3800
  • Firmware Version: V1.0.0.58_1.0.38
Went through WPS setup and manual setup.  Haven't gone through setup while hardwired.  2.4g works fine.  5g shows connected between Router and EX3800 but I cannot connect a 5g capable device to the EX3800.  I have great signal between the router and extender and the extender and the end user devices.  Has anybody run into this problem and have a solution?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello soundcrossing
    I would try to factory reset and do the setup again you may want to try the wired setup.
    DarrenM
