tdebacker
Sep 04, 2020Aspirant
EX3800/AC750 not sharing internet when restarted
Hello Everyone, thanks for reading !
My issue is the following: I followed the installation procedure and my extender replicated the wifi's of my router, I can connect to it but there is no internet available :-(
I tried this: I did the same with a cable and then I removed the cable: it was successfull !!!! BUT then, I switch off and bring the extender to its final destination and when I plugged it to the power again: same issue, evertything looks fine from a network point of view but no internet :smileymad:
Please could you suggest something ?
Many thanks in advance,
Thomas
so you were able to set it up using the installation assistant if ran in the same room?
When you set it up using the cable, was it cabled to the router? If so, that sets it up in access point mode. If you meant you set it up with the cable to a computer, thats different.
How far did you move the extender from the router?What are the interior walls in your home made of?
What are the led's on the extender showing when you moved it? (all of them, blinking/solid/color)
Firmware on the extender?
- tdebackerAspirant
Thanks for your message.
The cable was between my main router (ASUS) and the Wifi extender ; the extender was not set up as an access point but well as an extender.
I did it again and it worked very well during 1 hour, and then no internet available ????
The distance between the router and the extender is 5 meters, my house is made of wood, neightbours are far.
When the extender is hardwired to the router it should be setup in access point mode.
when wireless is when you use extender mode.
Are you setting up using wps or the installation assistant?
What firmware is on the extender?
What router are you connecting to?
