wwcole1's avatar
wwcole1
EX3920 - Connected, no internet
Hello everyone,
I purchased my AC750 last week. I have set it up as per the instructions say, setting up my iPhone X, Roku TV, and my Lenovo laptop. Both my TV and laptop work perfectly and I have no troubles there, but for some reason it will not work with my phone. I can connect to the 5GEXT and it will tell me that I have internet, but all of the apps I go on it tells me “no internet connection”. I have no clue what is wrong and it really has been frustrating me. So, if anyone could help me out I would be extremely grateful.
  • StephenB's avatar
    Is either the laptop and TV using 5GEXT?
    Can you connect the phone using 2.4 ghz?
    • wwcole1's avatar
      wwcole1
      I can connect to the 2.4G, but it is the same as the 5G. Both my TV and laptop are also on the 5G.
      • StephenB's avatar
        Ok.  So the issue is with the iphone specifically and not the network.
        I've seen a couple of other posts where folks have struggled with iOS.  Unfortunately I haven't seen a good resolution - hopefully someone here who's solved this problem will chime in.
