bluebell8111
Oct 15, 2016Follower
Ex6000 and Sky
For some reason I am unable to connect my extended to my Sky router, please could someone let me know if the extended can be used with a Sky router. Thanks
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Bluebell8111
Have you tried to connect via WPS and also the manual connect? Is your sky router using WPA2 security? Also you may want and try to factory reset the extender before trying to set it up agian.
DarrenM
