Shawn2182
Sep 09, 2016Follower
EX6100 Extender not restricting Parental Controls setup from Router WNDR3700v3.
I have parental control set-up and working effectively (Genie) from my Netgear Router (WNDR3700v3) A few months ago I installed a Netgear EX6100 Extender in my house, and expected the (router source...
DarrenM
Sep 15, 2016Sr. NETGEAR Moderator
Hello Shawn2182
What you will need to do is log in to your router and find the DNS server that is being used this is typically shown in the Internet settings copy this down. Next you will want to log into your Ex6100 and go to Internet setup and switch it to Use a static Ip address here you will want to change the DNS to the same DNS that the router is using. This should make the Parental controls work on the extender.
DarrenM
oneflame
Mar 10, 2017Tutor
Hello,
I have the EX6400 - and have this same exact problem. How do I find advanced settings from the user interface?
Also - it appears that the router is registering each device under the extender's MAC address, and not correctly using DHCP Relay to forward client MAC addresses to the router for IP reservations, etc. Might this be the cause of the Parental Control issue?
Thanks for any help!
