stubby's avatar
stubby
Guide
Nov 28, 2018
ex6100 speed stuck at 150mbps
I just completed the setupe for the range extender and have been testing sppeds throughout the house on the old 5g and new ext5g.
when in the same room as the router on 5g from router speed is 300mbps, when on the 5g ext speed form extender is 150mgps max.
Are settings that need changed to fix this?
  • StephenB's avatar
    Is this measured throughput, or are you reporting the wifi link speeds?
    Is the router 802.11n, or is it 802.11ac?
    • stubby's avatar
      stubby
      Guide
      router is 802.11n
      speed I am reporting is from the wifi access connection
      right now 300mbps on 5ghz from router wifi
      and 150mbps when on the ext5g exntender channel
      • StephenB's avatar
        That would be the link speed.
        Can you try measuring throughput with speedtest.net, and see how that compares?
        Also, check the link speed again after speedtest.net finishes.
