Souwester
Mar 07, 2022Tutor
EX6110 Setup
I've followed the set up instructions, lights come on etc, I can 'see' the SSID plus EXT (both 2G and 5G) but when I enter the password (same as for the router) it comes up with 'Incorrect password ...'
Can't get beyond here, so help please.I have reset bothe the router and the extender with no change.
Thanks,
did you set it up using wps?
Sadly, to frequently wps gets coded different between manufacturer's (it shouldn't).
In those cased, try factory resetting the extender and installing it using the installation assistant instead.
Thanks for reply, but that's not working either - i can't get mywifiext page to load, have tried the 192.168.1.3 approach also, just not happening.
the "192.168.1.3" approach?
I mean push and hold reset for 7-15 seconds while its powered on.
Then follow the installation assistant. heres a video.
https://www.youtube.com/watch?v=yJVklshxBMk
