TheBogeyMan
Jul 19, 2017Tutor
EX6120 - no network connection on 5GHz
Installed and configured my.EX6120-100NAS. During config phase all was good - picked up both 5GHz and 2.4GHZ networks. But when it restarts it will only provide a network connection on the 2.4 networ...
TheBogeyMan
Jul 21, 2017Tutor
I could. I did. Multiple times before I posted this. The 5G never "went away". It just won't connect and get a connection.
I set up the unit while next to the router. Same deal.
I set up the unit while in the location where it needs to be placed. Same issue.
I did this at least 4 times.
As I said, during the config phase, it is able to pick up both the 5G & 2.4G networks (with a signal strength of 100% on both bands).
Unless I exclude the the 5G band it does not pick up a network when it restarts and does not assign the connected device a DCHP-assigned IP address.
DarrenM
Jul 24, 2017Sr. NETGEAR Moderator
Hello TheBogeyMan
Have you tried to lower the wireless channel on the 5ghz network on the main router?
DarrenM
