GerhardS's avatar
Jan 04, 2021
EX6120 Firmware Update
Using the EX6120 without any problems for a couple of years, but after a move I had to reinstall my network and did an update on the firmware as well. Done this update, the unit is working properly in the network, but I cannot access via the Web browser anymore. The firmware installed actually is version 1.0.0.54
  • when you're trying to access it are you using the mywifiext . net or the ip address?
    Try logging into the speedport and finding the IP address for the extender and use that to connect to it.
  • plemans's avatar
    what modem/gateway did you connect it to?
      • plemans's avatar
