jpc-14
Mar 10, 2017Aspirant
EX6130 wtf...
I bought that piece of .... EX6130-100FRS... using wps on basic configuration takes 2 min to complete at least... anyway i was looking for using it as an access point.
Factory Resetted it, powered it waited for green led, no wps (as access point) plugged in the ethernat cable to my router (set with ip 192.168.3.1)... guess what?
that .... can't connect. I suppose the piece of junk can't have an ip different from 192.168.1.X assigned.
anyone have informations about it?
got 2 weeks to send it back which i'm about to do if this problem is confirmed in order to take a true router.
Thanks
- jpc-14Aspirant
Edit:
Used manual configuration set it's ip manuallu to an available one... same result no internet , can't connect fully, limited access.
- DarrenMSr. NETGEAR Moderator
Hello jpc-14
You may want to check out page 16
http://www.downloads.netgear.com/files/GDC/EX6130/EX6130_EN_UM.pdf
DarrenM
