Geolem's avatar
Geolem
EX6150 - 5 Ghz - On which channels can it connect on router ?
Hey Guys,   I have bought a Linksys RE6400 Extender and I discover that it cannot connect on my router over others channels than 36-48. It is a problem for me because the channels 36-48 are stupid...
  • netwrks's avatar
    netwrks
    Feb 12, 2016
    The EX7000 as an Access Point is a great idea. and, you can also use the ethernet ports on the EX7000,  that woud resolve your problem, or depending on the type of switch you have, just plug the EX7000, into one of our switch ports, configured as an Access Point.
