Davelehardt
Sep 23, 2016Aspirant
EX6150 as a wfi extender with powerline extenders
I have an EX6150 already and want to add powerline extenders to my network. I noticed in the powerline +WIFI option, the WIFI extender looks nearly identical to the EX6150. So my question is this, if...
TheEther
Sep 24, 2016Guru
You can connect the EX6150 to a Powerline network via an Ethernet cable. The EX6150 will function as a Wi-Fi Access Point. You will need to flip the Access Point/Extender switch to Access Point on the EX6150.
- DavelehardtSep 24, 2016Aspirant
Thanks, appreciate the feedback, but I understand that about the EX6150. But what I'm actually wanting to know is can the EX6150 accept the network signal via its power plug (like the WiFi portion of the PLW1000 package, seeing as what's depicted appears to be externally identical to the EX6150)?
Thanks again,
Dave
- TheEtherSep 24, 2016Guru
The EX6150 doesn't have any Powerline capability.
