mpen
Jul 28, 2018Aspirant
EX6150v2 – AC1200 WiFi Range Extender won't connect to router
Hey, my EX6150v2 AC1200 Range extender won't connect to my router. I have tried the WPS buttons on both as well as logging in via the installation assistant - the extender's Router Link LED has never...
DexterJB
Jul 31, 2018NETGEAR Moderator
Hi mpen,
Welcome to the community!
1. Are you getting an error during the setup process?
2. Please make sure that you are using the correct password for the router during setup.
Dexter
Community Team
- DexterJBAug 06, 2018NETGEAR Moderator
Hi mpen,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- mpenAug 11, 2018AspirantHi Dexter
Yes I was still getting the issue. I did some online research and apparently the Hitron router I have is notorious for not connecting to extenders. I have bought myself a power line adaptor which does the job. Thanks for following up!
Mike
