mpen
Jul 28, 2018Aspirant
EX6150v2 – AC1200 WiFi Range Extender won't connect to router
Hey, my EX6150v2 AC1200 Range extender won't connect to my router. I have tried the WPS buttons on both as well as logging in via the installation assistant - the extender's Router Link LED has never...
DexterJB
Aug 06, 2018NETGEAR Moderator
Hi mpen,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
mpen
Aug 11, 2018Aspirant
Hi Dexter
Yes I was still getting the issue. I did some online research and apparently the Hitron router I have is notorious for not connecting to extenders. I have bought myself a power line adaptor which does the job. Thanks for following up!
Mike
Mike
