SilentCobra
Sep 05, 2019Follower
EX6150v2 extender will not connect to my router using WPS
I am trying to set up my extender using WPS both router and range are netgear and router uses wps. The range would not connect to router. The only time it does connect is if I use Access Point, howev...
- Sep 10, 2019
SilentCobra,
Please factory reset the extender by pressing on the small black button using a pin for 15+ seconds then join the NETGEAR_EXT wifi network using a phone or laptop. After you connect to the NETGEAR_EXT network with your phone or laptop, browse to www.mywifiext.net and follow the setup instructions
~Christian
Christian_R
Sep 10, 2019NETGEAR Employee Retired
SilentCobra,
~Christian
