captainturk's avatar
captainturk
EX6150v2 resetting to factory defaults
My EX6150v2 is resetting itself to factory defaults. I'm guessing after a powerful outage, but unsure.  It's configured for access point and type ethernet running firmware 1.0.1.108. But when it arbitrary resets, it leaves my entire network exposed as it fails open.
What is causing this, how to prevent it and if it has to reset, reset closed and prevent unauthorized access?
  • CrimpOn's avatar
    CrimpOn
    captainturk wrote:
    it fails open
    Please explain what "fails open" means.
    • captainturk's avatar
      captainturk
      CrimpOn, for example, a firewall configured to fail closed will block all traffic if it crashes, preventing unauthorized access during the failure. In physical security, a courthouse metal detector failing closed means no one gets through until it's fixed.
      When the EX6150v2 reverts back to factory defaults on its own, it should prevent unauthorized access and fail closed as opposed to failing open and allowing anyone within range to access my network (i.e. open Wi-Fi with no encryption.)
