PRrunner
Apr 17, 2016Follower
EX6200 Wifi Range Extender External Antennas
Placing the extender in the vertical position, Does one of the two 5dBi external antennas is to receive the signal from the WiFi router? If so, Which of the two 5dBi external antennas (the top or the...
rrhh
May 13, 2016Aspirant
I have a similar question.. I'm hoping to use a high gain directional antenna to connect to the remote wireless router to sow longer distance from the Netgear extender. and use the standard 5db antenna to connect to the wireless devices. can one of the antenna connectors be configured for the back haul and the other for client/device access?
- DarrenMMay 20, 2016Sr. NETGEAR Moderator
Hello Rrhh
You may want to check this article out about Fastlane Technology may help you.
http://kb.netgear.com/app/answers/detail/a_id/24662
DarrenM
