GreyNomadAus's avatar
GreyNomadAus
EX6200 Wifi visible but cannot connect
Firmware EX6200-V1.0.3.74_1.1.109 has been installed and the WiFi network is visible however I cannot connect to the extender using WiFi.  I can connect the extender to my PC and manage the network but not using WiFI.  The signal strength is good.
Any suggestions would be appreciated.
EX6200.pngc
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello GreyNomadAus
    Have you tried to access the extender by using the Ip address and not the www.mywifiext.net?
    DarrenM
    • GreyNomadAus's avatar
      GreyNomadAus
      Thanks for your response and yes I can login using the IP address.  What is interesting is that after a few restarts of the Extender I can now also login using the mywifiext.net address.  I don't know why but so long as I can log in I am happy.
      Russell
