adamslater
Sep 13, 2016Follower
ex7000 access point or extender
I cannot stay connected on my ps4 with my ex7000 I have it setup beside my ps4 with a lan connected to it. It is currently in extender mode. Would it work better if I moved it and connected it to my r...
DarrenM
Sep 15, 2016Sr. NETGEAR Moderator
Hello adamslater
It would be more reliable for gaming if you made it a AP and connected it to your router via ethernet. But you may want to try and change your wireless channel on the router to see if that helps the connection.
DarrenM
