Geolem's avatar
Geolem
EX7000 as Access Point - LAN port still usable ?
Hello Guys,
By reading the User Manual before buying, I found something which annoying me...
On page 19 from the User Manual, I found :
In access point mode, you can connect your computer or WiFi device to the extender only using a WiFi connection.
So... IF in Access Point mode, the 4 others LAN ports are not usable like a switch ?
Isn't it ?
Thanks for your time.
  • In Access Point, the LAN ports are usable.
    • Geolem's avatar
      Geolem
      Hello netwrks,
      Purchase done (110€ at Amazon.fr).
      Happy to come back on Netgear product.
      Thanks again for your time, you have help me on a previous thread and finally choose this due to great discount.
      • Geolem's avatar
        Geolem
        Sad time... I just received it and it is an DAO :(
        Unfortunately, I came across a defective product at unpacking.
        I wanted to set it up in Access Point mode, but it did not detect the DHCP server.
        After I configure a static IP, I set the wifi but nothing happens, the web interface shows me that the channel 0 is assigned both 5Ghz 2.4Ghz that ... Of course, no PC or iPad, or Smartphone finds the SSID (configured yet broadcasted).
        I performed the upgrade to the latest release. Same symptom.
        I try to factory reset and put it in its simplest config. Still does not work.
        I try as a repeater configuration, it does not detect wifi close (although a lot can be received).
        So I think that the product is defective at the opening. Too bad, but it can happen.
        I prefer not to continue the adventure with a replacement model.
        Then Netgear does not work with DFS 5Ghz channels in Europe.
        I put it in US region, I got more channels but still buggy.
        So sad :(
        Amazon return.
