Tazze
May 05, 2021Aspirant
Ex7000 doesn't connect to wifi anymore.
I have the AC1900 Wifi Range Extender EX7000 and my home had recently got the Orbi mesh extender or whatever. Though for some reason, after installing the Orbi mesh thing, my extender doesn't connect to the router anymore. The 2.4 ad 5 ghz LEDs are constant amber and the the LED below that blinking green. The WPS button doesn't work either, like none of the LEDs change like in the instructions, and the factory reset has also done nothing, no matter for how long I hold it. This wifi extender has never been dropped or received any kind of physical damage, so I have no idea why this might be occurring.
you might be able to connect the extender to the orbi network but it won't integrate with it.
You'd want to install it using the installation assistant and I wouldn't use it as a mesh device. (give it a seperate ssid)
It doesn't have the dedicated backhaul the triband orbi's do.
So if you really want to add it try setting it up using the installation assistant and NOT wps.
