mrund
Mar 07, 2016Follower
EX7000, loss 5Ghz SSID / all connected devices
Been using my EX7000 as an accesspoint, both 2.4Ghz and 5Ghz for clients. The EX7000 is connected with wire. Once a week or every second week at least, all clients connected to 5Ghz will loose t...
DarrenM
Mar 16, 2016Sr. NETGEAR Moderator
Hello mrund
I would try to change the wireless channel? also I would try a factory reset on the EX7000 see if that helps with the issue.
DarrenM
