DrCharlesForbin
Apr 17, 2017Apprentice
EX7000 no internet connection
Ok - I'm stumped on this one and I'm not paying $50 for a support call if I cana get a new one for $100. Recently, my EX7000 (in Access Point mode) has been reporting that it has no internet connection. However, it passes internet traffic just fine to it's wired and wireless clients. I've done a factory reset, gave it a static IP/DNS address, everything I can think of and it stll tells me that I have no internet connection to the AP. I've shut off the USB side as well, same problem. Fast Lane is not enabled. The log on my router isnt showing any errors and I've rebooted the entire network stack a couple of times in the proper sequence. I've tried going back to an older version of the firmware - same problem. Everything I do, same problem. Sometmes AP don't get their own IP address, and that's fine - but this looks like a DNS problem to me. But then why is flagging it as an error and why would it start now when it's been working like a champ for over the past year and 1/2. I wouldnt care if it doesnt have it's own IP address, but I'm having a problem getting a wifi signal sync'd up via WPS to a tivo adapter - it's not connecing to the internet. It was working until this Saturday when I switched out the TiVO. I can't fix that problem until I know what to do about this. Any suggestions - what am I missing? Thanks.
- AugelloTutorMy unit is new and has same issue. Works OK but STATUS page says 'not connected to internet'. After reading the previous comments it's clear that this fabulious device was programed to test internet connectivity by pinging netgear.com which will not respond to PING so the device says "no internet'. Now that's just a guess on my part since i'm not taking the effort to setup a sniffer. Why programmers hard code basic things like a ping address is beyond me. If you want to test the internet then ping the default gateway and give a success or failure on that and say 'Gateway found' if you don't have internet then check the Gateway. So my unit has a STATUS of X Not connected to the Internet when in fact it is connected to the Internet and I wasted 2 hours of my valuable time troubleshooting Netgears mistake. Good hardware; poor programming; horrible support. My own fault for not buying another brand.
DrCharlesForbin wrote:Ok - I'm stumped on this one and I'm not paying $50 for a support call if I cana get a new one for $100. Recently, my EX7000 (in Access Point mode) has been reporting that it has no internet connection. However, it passes internet traffic just fine to it's wired and wireless clients. I've done a factory reset, gave it a static IP/DNS address, everything I can think of and it stll tells me that I have no internet connection to the AP. I've shut off the USB side as well, same problem. Fast Lane is not enabled. The log on my router isnt showing any errors and I've rebooted the entire network stack a couple of times in the proper sequence. I've tried going back to an older version of the firmware - same problem. Everything I do, same problem. Sometmes AP don't get their own IP address, and that's fine - but this looks like a DNS problem to me. But then why is flagging it as an error and why would it start now when it's been working like a champ for over the past year and 1/2. I wouldnt care if it doesnt have it's own IP address, but I'm having a problem getting a wifi signal sync'd up via WPS to a tivo adapter - it's not connecing to the internet. It was working until this Saturday when I switched out the TiVO. I can't fix that problem until I know what to do about this. Any suggestions - what am I missing? Thanks.
- DrCharlesForbinApprenticeYep. It’s strictly cosmetic. I expected them to have the supressed in later firmware revs. No more consumer network hardware for me, just because the support is horrible. Maybe I’m paying for it with commercial hardware but it actually works. I’m going to taking a hammer to my 7000 very soon simply out of fustration. As much as I want to save it for use as a guest AP...I’ll get more satisfaction from the hammer.
