davidgsmith1's avatar
Aug 22, 2024
EX7000 Wired to router
Hello, is it possible to connect the extender to the router by ethernet to extend the signal, rather than wifi?
  • plemans's avatar
    Aug 22, 2024
    davidgsmith1 wrote:
    I just found out that the EX7000 does not support Access point. I need to buy another extender
    Who told you that?
    there's a few low end models that don't support AP mode but I haven't found any of the higher ones that don't.
    And we're talking really low end like the EX2700.
    I've got a EX8000 and an EX7300 and both support AP mode. I don't specifically have an EX7000 but even the manual (page 18) says it supports access point mode.
    https://www.downloads.netgear.com/files/GDC/EX7000/EX7000_UM_EN.pdf
