PRK123
Aug 12, 2019Aspirant
EX7000 won't allow wireless connection after firmware update
I recently updated my EX7000 to Firmware Version: V1.0.1.80_1.0.144. After that firmware update, the following devices were no longer configured/connected as they were prior to the update:
- 2 - Honeywell WiFi Thermostat, model RTH8500
- I attempted to reconnect the thermostats following the Honeywell User Guide.
- I follow the steps, but the Thermostat displays "CONNECTION FAILURE" upon completion.
- I connected one of the thermostats to my AT&T U-Verse Modem/WiFi Router so I know the issue is with the EX7000.
- The other thermostat is located beyond the range of the AT&T U-Verse Modem/WiFi Router.
- 3 - FDT Wireless Security Camera, model FD7903
- I attempted to connect the cameras following the FDT User Guide.
- Following the setup guide, I connected a camera to the EX7000 using an ethernet cable successfully. When I disconnect the cable, the camera does not connect via WiFi as it should.
- I connected one of the cameras to my AT&T U-Verse Modem/WiFi Router so I know the issue is with the EX7000.
I'm fairly technical, but I'm stumped. The following devices reconnected to the EX7000 WiFi with no issue after the firmware update:
- iPhones
- HP 6700 Printer
- Direct TV
- Roku
- 5 Woods WiFi Timers
Any help is greatly apprectiated.
Thanks,
Paul K.
- DarrenMSr. NETGEAR Moderator
Have you tried to adjust the wireless channel at all on the extender or the router that the extender is connected to?
DarrenM
- PRK123Aspirant
I changed the channel on my AT&T Modem/Router but I am still unable to connect the devices to the EX7000.
- Christian_RNETGEAR Employee Retired
Hi PRK123 - Thanks for confirming. I'd like for our Support Team to contact you for further investigation. Please send me a message with your contact info.
~Christian
