Wenen's avatar
Wenen
Ex7300 can’t do a new install
I just factory reset my Ex7300, and now I can’t do a new login account. I can enter new password, username and security questions after they it just say waiting and a spinning around symbol showing… I try a new factory rest did not help. But I can connection to my router without any problem, I’m just clicking WPS button on the router and ex7300 every led light are green.
  • plemans's avatar
    Since you hit the wps button, factory reset one more time.
    To factory reset, push and hold the reset button for 7-15 seconds while powered on.
    Here's a video of how to use the assistant.
    https://www.youtube.com/watch?v=yJVklshxBMk
    Make sure when you set the admin password to meet the minimum requirements.
    You can also try using a different device for setup.
    • Wenen's avatar
      Wenen
      Thank you! I think i did the reset think right, but I will try one more time. It’s something very weird about the making a new installation part. I have try on iOS, android and windows noting works
