jpd99's avatar
jpd99
Guide
Feb 10, 2022
EX7500 issues keeping 2.4GHz devices connected
EX7500 is connected to R7800 router.  5GHz devices do not have an issue but 2.4GHz devices will connect for a day or 2 and then looses connection.  Once that happens I can not get them reconnected unless I pulll the power on the extender.  All firmware is up to date.  This has happened from the beginning.  I was originally thinking it was a problem with the 2.4 devices but now convinced it is the extender.  2.4 and 5 GHz are configured with the same name.  I don't think there is anything I missed in my configuration?  Is there another recommended extender I should use with my R7800 router?  Thanks.
  • Not on the R7800.
    Just went you're going through setup of the EX7500. It asks you if you want to extender the 2.4ghz. Deselect that.
    You'll still be able to use the 2.4ghz, it just doesn't use it as a failover if the 5ghz has an issue. Leave the 2.4ghz broadcasting on the R7800.
    You can try changing which channel you're broadcasting on.
  • plemans's avatar
    When you setup the EX7500, did you check off the box saying "extender 2.4ghz network"?
    if so, factory reset the extender and during the reinstall with the extender, uncheck that box. You can still use the 2.4ghz network but it won't use it as a failover for the wireless backhaul. sometimes that helps.
    You can also try changing which channel the 2.4ghz broadcasts on.
    What firmware is on the extender?
    What firmware is on the router?
    • jpd99's avatar
      jpd99
      Guide
      Firmware V1.0.2.90 on R7800
      Firmware V1.0.1.76_1.0.80 on EX7500
      EX7500 Configuration:
      Enable One WIFI Name = Yes
      Enable Smart Connect = Yes
      Sync Configuration fom Netgear Router = Yes
      Check marks are gray but both 2.4 and 5 are checked.
      In the past I have reset to factory.  Unchecking 2.4 at the point of reconfiguring might work?
      • plemans's avatar
        I usually uncheck the "extender 2.4gh" during setup. Tends to be more stable as it relies on the 5ghz and won't failover to the 2.4ghz.
        also, make sure the R78000 is using the higher 5ghz channels to broadcast on.(not dfs channels)
