ae6dx00
Mar 31, 2018Guide
Ex7500 looses connection
I have an EX7500 and a Nighthawk X10. They have worked fine for the last week or so since I got the EX7500. Today the EX7500 router light on far left keeps turning red. Yet I'm able to access mywifiext.local but it shows disconnected under the network (see attached screenshot). I have not moved anything around. This judst started all of a sudden. What can I do to fix this?
I primarily got this to get better coverage outside in the back yard but I've noticed some of my sonos devices have latched on to the extender. If the extender looses connection so9 do they. If it goes offline do the devices that were attached to it not try to pick up a signal from the main router (as they were before I had the extender)?
- jvasanth1984Virtuoso
Hi ae6dx00,
I would recommend you to modify wireless channel on the router and check if that helps. If persist, reboot router and extender in sequence to see if that resolve the issue. In case if you still come across the issue, look for interference devices if any. Any bluetooth speakers like Sonos will affect its signal if it is close to it. Try to move them away a bit to see if that helps.
- ae6dx00Guide
How do I know which channel to use? Router is currently on Auto. Does the extender have its own channel?
If the extender shows disconnected as in my screenshot how am I able to access its settings page?
Hi ae6dx00,
2.4GHz shows disconnected whereas 5GHz is still active, but have weak signal. You can login to it using mywifiext from windows PC or using mywifiext.local from any MAC PC or iOS devices or by IP address of it from android mobile. You cannot change the channel for extender since it reply on router's channel. You can try channels like 1, 6 and 11 for 2.4GHz and 44, 48, 153 for 5GHz. If you have android mobile, you can use wifi analyser app which can help you to identify best channel for your environment.
