Johnny_Wolf
Sep 02, 2018Aspirant
EX8000 extender installation with a Nighthawk X6S router
Hi all,
When installating my extender I get some information, see text in blue below.
I get two questions about this:
1. The channel from the extender seams to be Ch 104, but I can't change the...
Sep 02, 2018Guru - Experienced User
Your R8000 router is a triband router - do you have both 5G radios enabled on it?
Johnny_Wolf
Hi, thank's for answering!
Yes both 5GHz radios are active, the second one is like a slave; I used Smart connect to get same SSID and password for them.
I added two pictures from the installation interface, but it seams like they only became "icons".
I'll try to add them again.
BR Johnny
