sschueller
Oct 18, 2016Aspirant
Extend wifi in two different directions from one router. Model EX6120
I am trying to extend our wifi in two different directions in a large home, where in both places the wifi does not reach. I set up one wifi extender, and it works to extend the wifi into one of the ...
sschueller
Nov 07, 2016Aspirant
Hi Thank you,
I did try to do the factory reset button. But that method still had the same results as the first try. And then our router does not have a wps button, so I was not able to try that method. Could this particular extender be faulty, as the other one works, but not this one? Or is the problem that one cannot use 2 extenders from the same router to extend in 2 different directions?
DarrenM
Nov 10, 2016Sr. NETGEAR Moderator
Hello sschueller
You can use 2 extenders but if you believe that maybe the extender is faulty and is still under warranty I would suggest contacting support as they would be able to RMA the extender if its having a issue.
http://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
