Asterion
Dec 09, 2014Novice
Extender changes IP addresss on the fly
I am expecting once I connect a device by ethernet that the IP address the extender gives it stays the same while the device is connected. What I am finding is that I connect to a small computer boar...
Asterion
Dec 16, 2014Novice
fordem wrote:
You need to determine where the connection is being broken - my suspicion is between the router and the extender (because you say the SBC is connected to the extender via Ethernet) and I have one more question - is it the extender issuing the ip address or the router?
Good question but how does one work that out? Basically, a telco has installed an ISDN router with wireless that I am tapping into and that I haven't touched. I have simply used the raw connection steps on the extender and have not changed settings from factory.
What is the default behaviour of the extender?
