DLGolfs's avatar
DLGolfs
Extender does not show up on network map
My extender does not show up on the network map; I have updated the firmware; reset the extender
The extender works but does not show up; I can tell it works b/c my cell phone uses wifi.
Firmware 1.09.32
Windows 7 Professional
Why isn't it showing?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    the extender will not show up in the map if you are talking about in the apps.
    DarrenM
  • I have NO idea what you are in reference.  Are you referring to an application on a phone?
    I am talking about the software on my desktop.
    • DarrenM's avatar
      DarrenM
      yes the genie app is what I am talking about. Extenders will not show up on the network map.
      DarrenM
