DrDoogie
Jul 12, 2015Aspirant
Extender (EX7000) can't see all 5Ghz networks
Hi folks Just received my EX7000, posting here until the unit gets its own forum:) The extender is connected to a Netgear R8000, a router with 2 separate 5 ghz radios in addition to a 2.4 ghz radio...
DrDoogie
Jul 22, 2015Aspirant
Thx for answering! It turns out youre almost right, except that the extender will not detect dfs channels. Non fds works great, but one of the radios only provide dfs.......
Ohboy108
Dec 21, 2015Aspirant
I was having an issue where my EX7000 extender didn't see or connect with my 5GHz network even if I entered it manually. Spend hours with tech support, returned unit which they said was defective and bought another sample but it had the same problem. I finally found this KB which solved the issue. http://kb.netgear.com/app/answers/detail/a_id/25057/~/why-can%E2%80%99t-i-find-my-5ghz-existing-network-(ssid)-when-i-try-to-install-my.
You're correct ... you have to use a non DFS channel.
But why couldn't tech support know that. Why is that info not in the instructions.
