DigDugDig
Nov 27, 2020Aspirant
Extender Firmware Upload?
I am new at this game. I just purchased this extender. I connected. My computer whilst loading password to the new WIFI advised me that the new extender is no secure. I went to support and downloaded a firmware update. I unzipped the file and saved it in a seperate folder. The instruction manual says then click the UPLOAD Button.
I do not see any upload anything.
I am totally confused. Any help for a newbie?
DigDugDig
DigDugDig wrote:I am new at this game. I just purchased this extender. I connected. My computer whilst loading password to the new WIFI advised me that the new extender is no secure.----that'd be wireless password more than likely. Unable to say 100% based off this limited info. I went to support and downloaded a firmware update. I unzipped the file and saved it in a seperate folder. The instruction manual says then click the UPLOAD Button. ---If you're following the guide, you log into the extender and go through its firmware update settings.
- On most models, select Settings > Firmware Update.
- If you do not see that option, select Maintenance > Firmware Upgrade.
DigDugDig
here's an article that walks you through it as well as a video.
https://kb.netgear.com/000057115/How-do-I-update-the-firmware-on-my-NETGEAR-WiFi-Range-Extender
- DigDugDigAspirant
Sorry, I read all that you alluded to and I watched the video. I am totally lost.
1) when I try to join the _2GEXT I am told there is a security problem and my computer will not allow me into the WiFi
2) when I join the _5GEXT and enter the address specified which looks something like "my wifi ext net". Then I receive a the screen that says "Not connected to extender". Then I enter the next instruction in the information you sent
"http // my wifi ext"( as the instuctions indicate for Windows) and I receive a page that says, "This Site Cannot Be Reached".
3) again like yesterday I begin to chase my tail running around in circles - I am not a moron, why is this so difficult?
I am prepared to return this extender. For goodness sake, they charge nealy $100.00 for a device that will not pass muster in the security features. Will not connect on one of the two bands. They suggest that you update firmware, the instructions take you into circles, nothing works.
Note: I update firmware on my printer, graphics card, and other components - I am no stranger to firmware. This is simply unacceptable.
I appreciate your attempt to help but it did not work. No doubt it is me that is the block head.
Sincerely,
DigDugDig
the EX6120 has an ethernet connection. Simply connect a pc/laptop to it. (disable the wireless on the device you connect to it to prevent that device from defaulting back to the wireless connection)
Then try following the guide
