JacquiJean
May 03, 2017Follower
Extender Incorrect Password
HI, I have an extender and since changing my internet provider whatever I try to connect my devices won't acceot the new password, saying it's incorrect. I've tried the set up wizrd just connecting t...
sjc501
Sep 06, 2017Aspirant
Hi I changed router and now my wifi extender wont let me log in says password incoreect .How do I tell it the new wifi password .Tried reset and it didnt work .Tried using the old wifi password didnt work.Any ideas.
- DarrenMSep 08, 2017Sr. NETGEAR Moderator
Hello sjc501
You will want to hold the reset button for 10+ seconds to factory reset the unit then you should be able to set up the unit for the new router.
DarrenM
