JacquiJean
May 03, 2017Follower
Extender Incorrect Password
HI, I have an extender and since changing my internet provider whatever I try to connect my devices won't acceot the new password, saying it's incorrect. I've tried the set up wizrd just connecting t...
sjc501
Sep 06, 2017Aspirant
Hi I changed router and now my wifi extender wont let me log in says password incoreect .How do I tell it the new wifi password .Tried reset and it didnt work .Tried using the old wifi password didnt work.Any ideas.
DarrenM
Sep 08, 2017Sr. NETGEAR Moderator
Hello sjc501
You will want to hold the reset button for 10+ seconds to factory reset the unit then you should be able to set up the unit for the new router.
DarrenM
