Tnga's avatar
Tnga
Extender not accepting router password- says incorrect password
My extender will not accept my network password. I have reset the extender and when it tries to connect to the network it says incorrect password. The password clearly works because all my other devices connected are working as well. I have had my extender for a little over a year.
  • plemans's avatar
    what router are you connecting it to?
    Are you setting it up using WPS for the install process?
      • plemans's avatar
        Tnga wrote:
        Charter router
        that could be any number of devices.
        Did you factory reset and try the installation assistant? using a pc/laptop and not the app?
    • Tnga's avatar
      Tnga
      It was working for a year and now I am trying to set it up again from factory via the night hawk app
