SexyClassy
Oct 12, 2017Follower
Extender WiFi Network Name & Password Issues
Hi there! New to the community... :)
I am trying to set up my EX 6100 Extender and having the hardest time. I followed the instruction manual directions to "Connect with WPS", and got to Step 4, where the Extender Wireless Name changed to my WiFi network name with _2GEXT and _5GEXT after it. However, it's showing the original WiFi network name (basically the Model number of the router), instead of my personalized network name that I had changed it to "Sexy Classy".
I'm not sure if this matters, but I'm wondering if there's an issue because when I try to access the Extender Wireless network, my original WiFi network password is not working, and Step 5 in the instruction manual says the passwords would be the same.
Has anyone else experienced this? Would love any help!
1 Reply
- DarrenMSr. NETGEAR Moderator
Try connecting to www.mywifiext.net login to the extender and change the password and see if that will allow you to use the wireless network.
DarrenM
