edjoella
Apr 19, 2024Follower
Extending ATT Fiber Gateway
Can I use my Netgear Universal WiFi Range Extender WN3000RPv3 to extend the reach of my ATT Fiber Gateway? Or do I have to rent an extender from ATT. If the Netgear extended can be used, how do I connect? There is no WPS button on the Gateway. Thanks in advance for any help offered.
1 Reply
set it up using the installation assistant.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMkI'd recommend upgrading at some point as that's a lower performing extender.
