alisilcock
Oct 29, 2015Aspirant
Extending internet to an outbuilding on a different circuit
Hi all, New to forums and quite a technical novice. I want to extend internet to my outbuilding. The outbuilding is c.35 metres at the bottom of the garden and is on a totally seperate electr...
- Oct 29, 2015
Yes, there's no reason why not, but if you have a power socket near to a window close to the outbuilding then you could consider using powerline products which have a AP at the remote end e.g. http://www.netgear.co.uk/home/products/networking/powerline/XWNB5201.aspx#tab-techspecs and if the WiFi isn’t quite strong enough then you still have the option for wired Ethernet at the remote end which you can connect to a more powerful AP.
alisilcock
Thanks. Could I set up the ex700 as an access point by connecting it via Ethernet cable to a powerline adapter? So in theory it is wired to the router, just via a powerline adapter?
Babylon5
Oct 29, 2015NETGEAR Employee Retired
