EllDee71's avatar
EllDee71
Extending Mesh
I have a NetGear Nighthawk MR60 mesh wifi router with 2 satelites , it is performing quite well.
 I am now building a detached garage approximately 50 feet from my house.  I alos have an EV and have bought a Chargepoint EV charger to go into my garage.
I am looking for the best Netgear solution to provide wifi in the garage.  It is not possible to run a separate ethernet wire to the garage.
I recognize that other posts have asked similar questions, but have not seen any discussion of chargpoint since 2019, any help appreciated.  I wonder if a range extender or another mesh satelite would work?
Thanks for your response
Larry
  • CrimpOn's avatar
    CrimpOn
    Does the garage have an electrical water connection to the house?  (thinking that construction of a new structure would be an ideal time to bury a 1" PVC conduit to allow installation of a network cable.)
    The generally accepted methods of extending service to a building are:
    • If within 300 ft. installing an Ethernet cable is the optimal solution.  Best performance.  Least complexity.  Often impractical.
    • If there is an electrical connection between the main building the new building, Powerline can often provide a good connection.
    • A "wireless" bridge will often provide adequate service.  Since these units are rated in terms of Kilometers, over a short distance they can often penetrate both the main and remote building walls and still get good performance.
    The biggest question is
    • Do you want WiFi in the garage that is networked to the primary network, or
    • Do you want to extend the seamless mesh WiFi system to the garage?  In that case, only another MS60 satellite will do what you want.
    I would start by purchasing an MS60 satellite from Amazon.  If it will connect with the main house, "problem solved".  If not, return it to Amazon and confront the issue of what performance is necessary.  For example, a WiFi extender will connect to the primary WiFi network over 2.4G at a greater distance than an MS60 satellite with 5G WiFi.  If the primary goal is to connect the Chargepoint to the network, that might do it.  WiFi extenders are relatively inexpensive.
    • EllDee71's avatar
      EllDee71
      Thank you CrimpOn. This seems like a good plan. The large metal garage door that faces the house goes up next week. At that point I will do the test with the satellite, but I am thinking to use one of my current units for the test.
      Just fyi I do have a pipe from house to garage to carry electric. However the building inspector doesn't allow electric & Ethernet in same tube, it would cost ~$2k to place an additional tube.
      Thanks again, LD
      • FURRYe38's avatar
        Something you could review and check into. Some power line adapters. Depnds if power is on same circuit though.
