longthan67
May 03, 2017Aspirant
Extending wifi doesn't work properly - EX6100
Hi all, I recently buy a Netgear wifi Extender - model EX6100 - to improve the range of my rent room ( landlord wifi sucks so bad - nearly out of range ). I installed it and within the first week...
DarrenM
May 08, 2017Sr. NETGEAR Moderator
Here is the page to download the Firmware you will need to log into the extender and upload the file to the extender.
http://www.netgear.com/support/product/EX6100.aspx#download
DarrenM
- longthan67May 08, 2017Aspirant
Thanks, I will try download later and let's see if it helps with the situation.
I have updated the firmware to the latest one but still no use. The funny thing is, I used my PC to download the firmware and update it but when i tried to check to update the firmware online option, it tells me that i have no internet connection???, so I have to do it manually. My PC connect to the NETGEAR_EXT2. Please help.
- longthan67May 11, 2017Aspirant
Anyone has a solution for this?? Should I try the customer support of NETGear?
