Overboard's avatar
Overboard
Follower
Dec 03, 2016
Extending Xfinity Hotspot
I had a 6150 which had no problem passing the Xfinity logon page to devices. Worked well.
But it decided to go overboard,so I got a 7300 figured it would work the same way. I cannot access the logon page with the 7300. Do I need to return and get a 6150 again? Or is there a way to configure the 7300?
Thanks,
   Frank
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello overboard
    You can try to go to www.mywifiext.net or if you are able to find the ip address of the extender in the routers page type that Ip into your browser and it should bring up the login for the extender.
    DarrenM
