jtwill98
Nov 05, 2015Follower
External Antenna for AC1200 WiFi Range Extender
A couple of questions regarding external antennas for the AC1200 WiFi Range Extender.
1) I have a yagi 2.4 GHz antenna. Which external connector should I use, top or bottom? Does it matter?
2) I have a connetion through the 2.4GHz channel, but the 5 GHz channel shows disconnected.
Do I need a seperate 5GHz Antenna?
If so, does it matter which connector is used with it?
1 Reply
- nhannNETGEAR Employee Retired
Hi jtwill98,
Please note that replacing the EX6200 WiFi extender antennaes will void your warranty.
The following antenna may help: http://www.amazon.com/Super-Power-Supply%C2%AE-TL-WDN3800-TL-WN851ND/dp/B013T5TA44Usually it is SMA type for the connector
