Urrno
Oct 17, 2018Aspirant
Extremely Slow Ethernet Connection Through Wifi Extender
I have my desktop hooked up to my wifi extender through an ethernet cable. Currently, my donwload speed is less than 1mbps. My phone, which is connected to wifi and is in the same room as the extender and the desktop, gets over 30mbps.
My internet speed was fine until yesterday morning. Since then, it has suddenly become so slow as to be unusable.
Can anyone help?
Did you try restarting the extender?
- UrrnoAspirant
Restarting the extender did not help much. My speed is up to 3 mbps, which is a little bit better, but not nearly as good as it should be.
What speed do you see if you disconnect the PC lan cable, and connect the phone to the extender's network?
You might also use the Windows task manager (clicking on the performance tab) - just to double-check that there isn't a background task that is using network bandwidth.
