glogrono
Sep 25, 2014Follower
Fastlane Technology
Hi everyone,
I'm trying to set my new extender to use the Fastlane Technology Device-to-extender in 2.4GHz only and extender-to-router in 5GHz only (Router must support 5GHz band), but when I choose that option and click apply, I get disconnected from the extender's network and then when I go back into Operating Mode settings, it is set back to Internet Surfing instead of the Fastlane Technology setting I just applied. My main router is a Buffalo Airstation 1300. Any help would be appreciated. I am also wondering how to get better link speeds between the extender and router. Right now, the 2.4GHz band is connected at 270Mbps, but the 5GHz is connected at 263Mbps.
1 Reply
- karthick1999Aspirantwhat you can do is you can reset the extender completely for two minutes and power cycle it for another two minutes. Then connect to Netgear_Ext and then you can log into www.mywifiext.net and then try the settings once again. Make sure that your WIFI devices are connected to 2.4GHZ default extender network name... If you have any issues you can reply here
