tperk's avatar
tperk
Finding MAC Address
May seem like dumb question but I cannot figure out how to get the MAC address. 2 MAC  Addresses on Extender label seem to be for connecting other devices to the extender. I need the mac to connect extender via WiFi to my FIOS G-1100 Verizon gateway.
Thanks
  • FURRYe38's avatar
    Is there any helpful information in the user manual for this?
    Does the setup wizard not help you connect the extender to the main host routers wifi?
    • tperk's avatar
      tperk
      Yes, but not to find MAC
      Yes, I am connected.
      Here's my problem. I have about 50 (many no name) devices conected to gateway, including the extender. I simply want to ID the Extender and change its name to "Extender." I am trying to ID all devices to make sure no one unauthorized is "borrowing" my network. It would be easier if the G-1100 has some way to sort or reorder the attached devices.
      • FURRYe38's avatar
        You can look at the sticker on the extender and see the MAC address here. Then look for this address on the main host routers connected clients table...
  • schumaku's avatar
    schumaku
    There are three MAC addresses: One of for the extender wired Ethernet, one for the 2.4 GHz and one for the 5 GHz radio. Unless I'm wrong, the two WiFi radio MAC are shwon on the top of the Connected Devices in the Genie Web UI.
    • tperk's avatar
      tperk
      Can you show me the Main MAC in this pic? The cropped out number is WPS Pin.
      • tperk's avatar
        tperk
        My pic is here when I post. When I come back its gone. Trying again. If pic's gone, click Unit Label attachment.
