LJDonleson
Mar 07, 2018Aspirant
Firmware update, now no connection to existing networke acccessed outside network
Hi, updated firmware (because it kept bugging me) and now the extender will not connect to the existing network. FW:v1.0.2.66. Does see router and asks for authentication during setup, but when c...
- Mar 09, 2018
Yes, passwords verified each time.
So I found a solution, but it makes no sense. The router was originally setup with a two word SSID, "FName SName" with a space in the middle. This works for every device connecting, including the extender, originally. Then the FW update and it still sees the router, but will not connect when setup is complete. After everything else had failed I thought, remove the space and see what happens so the result is "FNameSName" (no space) and success. Looks like the FW update has a nasty new requirement not previously documented.
For all you smart guys who knew this, or those who want to elucidate the masses, don't. If I want a two word SSID in my router and everything works, then fine, my choice. If it works before the update it should work after the update.
Hope this helps someone else.
jvasanth1984
Mar 09, 2018Virtuoso
Hi LJDonleson,
Are you sure if you are inputting correct password for exisitng network during setup? If yes, do you have access control enabled on your Router? Try to modify wireless channel on Router and see if that helps.
LJDonleson
Mar 09, 2018Aspirant
- jvasanth1984Mar 09, 2018Virtuoso
Hi LJDonleson,
Good that you resolved it by removing space in SSID. I'll check on this issue since you claim that it worked in previous firmware.
Hi LJDonleson,
I checked on this where it works even after firmware upgrade to latest version with space in SSID. What characters are you using in SSID? What is the security type your router is using? How many space do you have in SSID?
- LJDonlesonMar 09, 2018Aspirant
SSID = Starfleet Communications
Security = WPA (PSK)
Worked before the update, did not after. I did everything I could for more than 2 hours before making that single change and suddenly it worked.
