Andre_Ventura's avatar
Dec 11, 2016
Firmware update on a WN1000RT
I use a WN1000RP to extend the range of a hotspot network provided by a closeby neighbor, which uses a captive portal approach.
After upgrading to the latest firmware release (1.0.0.52) that became impossible, I enter an endless configuration process.
I tried with another type of network, using WPA-PSK, and suceeded. But cannot use an open one with a captive portal.
Is it possible to have a previous firmware release to be back on business?
And after having it is it possible to flash it, removing the newer one?
Or could NETGEAR provide a firmware without this incomprehensible limitation?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Andre_Ventura
    The home extenders are not meant to be used with these type of login pages you may have to look at a business extender for something like this.
    DarrenM
    • Andre_Ventura's avatar
      Andre_Ventura
      That is not a proper answer. There no standard definition of home extender vs. business extender. If I had the problem in the beginning I would had return the equipment immediately; now I cannot do it anymore. So, the solution may either install a previous firmware, or to get a new one, without this limitation.
