Jeff_Lindstrom
Jun 18, 2020Follower
Force a 5GHz connection from Repeater to Spectrum router
Our new Spectrum WiFi Router decides whether to connect to a device on the 2.5GHz or 5GHz band based on signal strength and, for the last couple days, it has been choosing the 2.4GHz band for my Repe...
Jun 18, 2020Guru - Experienced User
Which spectrum router is it?
Many you can disable band steering.
